Porsche 944 Front Bearing Cap (1) - 5x130 Spacers (0)
That alluminium must be very weak ,i wouldn't use those spacers. I machined mine to fit over the bearing cap ,only downside is that you loose the centering ring , spacer to wheel.
So this spacer is intended to bolt to the hub then the bearing cap is pressed into the spacer opening? Or was it designed to fit over the hub with bearing cap below the spacer?
WOW... cheap spacers FTW!!!
Not trying to be a dick...but there is a reason some spacers cost $400.
1. They fit over the hub and cap without machining
2. They are not cast aluminum. They are machined billet.
Its probably good they broke then, and not when you were driving.
