Rough Idle When Starting Up...
Old 08-06-2011, 11:08 PM
Ed Petry
Ed Petry's Avatar
Hi Everyone,
The problem is the short air line from the ICV to the intake manifold. A half-inch to three-quarter inch tear was passing "un-metered" air into the system. All rubber under the manifold (including the ICV mounts) on order so the car will cruise again.....SOON I HOPE!!!!!!!! Thanks to everyone for the help and advice!!!!!!!
Old 08-07-2011, 12:23 AM
plumbum
plumbum's Avatar
Do you have a picture of the hose? I might have the same problem. My car wont idle when cold...everything tested ok...I also notice with the warm weather and AC on the idle is lower around 600rpm causing it to be rough...worse when cold. I havent gotten around to taking the intake off to have a look yet.
Old 08-09-2011, 07:40 AM
Ed Petry
Ed Petry's Avatar
Hi plumbum --- sure, pix are no problem. may take a day or two as life is busy.
Old 08-09-2011, 04:25 PM
plumbum
plumbum's Avatar
great! Thanks!!
Old 08-12-2011, 11:04 PM
Ed Petry
Ed Petry's Avatar
Hey Plumbum--have pix but can not find way to post to the board. If you want to see them email your addy & iI will return 5 or 6 pix. Cheers--Ed
Old 08-13-2011, 03:19 AM
plumbum
plumbum's Avatar
Great thanks Ed!
Old 08-28-2011, 09:06 AM
Ed Petry
Ed Petry's Avatar
Hey Plumbum--car is running better than it has for the two years I have owned the car. I suggest this repair if there is any question. Good luck.
Old 08-28-2011, 09:57 AM
plumbum
plumbum's Avatar
Thanks for the update! Will be ordering all the rubber and likely a new icv while I am in there.
Quick Reply: Rough Idle When Starting Up...
