944 turbo timing
hi guys
i just recently purchased a 87 porsche 944 turbo. the car seemed to run fine but when i took it in to get smogged everything except the air was high. i took off the timing cover and the timing marks was were they suppose to be except the cam mark was around the 3-4 o'clock position. if i turn the cam to the correct position will i break something. what is the correct way to adjust the cam timing
thx
thx
Start with Clark's Garage:
http://www.clarks-garage.com/shop-ma...3.htm#camshaft
There's also the Haynes manual, the factory workshop manuals, and plenty of threads here on the topic if you do a search.
