A/C O-rings
It's bloody hot so I figure it's time to get some A/C in the car. Not quite the 134 of last summer but I do get cranky. I have a used compressor and a new drier and a new expansion valve. I'm going to go with R134.
1. Is it possible to replace the shaft seal on the used compressor.
2. Where are all the o-rings located? I'm going to replace all those with green o-rings.
2 o-rings at the compressor, 2 at the condenser, 2 at the receiver drier, and 2 at the firewall.. FWIW, Harbor freight sells a combo box full of em for about $8.. more than enough to do the 3 cars I have done with em!
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
Some of the lines at the fire wall can be difficult to replace. Buy a small bottle of ESTER OIL to lightly coat the seals while installing. Use some Brake Cleaner on a rag to clean the line ends prior to installing the new seals. I don't know about the compressor shaft seal. You might ask around at the store you work for if anyone knows someone who does it on the side.
Cheers,
Larry
Cheers,
Larry
