944/2 NA Instrument bulb replacement
Hey guys,
Need the technical input on this one.
I've had my cluster apart to fix the odometer gear and "while I was in there", I replaced all the bulbs including inside the cluster (coolant, battery,oil,fuel). Upon testing to make sure the low fuel light came on, I ended up on the side of the road. So I'm doing it over again. Called the dealership and ordered the parts (bulbs), but after the phone call I wasn't too sure on the right ones. I remember some differences. (two being push in prongs, two being twist). I'm not positive though and could use some help. If you have the part numbers or know what the bulbs should be corresponding with this:
http://www.autoatlanta.com/porsche-p...-88/906-00.php
The bulbs are for #1 and #4. INSIDE (I must stress this, INSIDE. As in you HAVE TO REMOVE those to get inside it to replace your Oil bulb, coolant bulb, low fuel light warning bulb, and battery bulb).
Porsche dealership said it's #14. I'd like to be positive here. I know I'll "find out when I crack it open again", but I'd like to be sure since they're not keen on returns.
Thanks in advance guys. And when I do this job again, I plan on doing a nice tutorial to increase the knowledge
