Fitment of RH 3.6 on 968
Hey, I've found a set of RH 3.6's in 18x8.5 et45 and 18x10 et40. I'd like to put them on a 968. The seller had them on a Boxster with no spacers.
From threads I've searched, there's many that say that they won't fit on late offset 944 series cars, but then I've seen a few fitting 996 turbo wheels on late offset cars, and Samluke fitting 18x10 et40's on the rear of his late offset car. Some say they will fit on lowered cars with some negative camber.
Will these fit on a 968 lowered with KW v3's?
I did some research and couldn't find anything conclusive, but this thread might give some insight:
https://rennlist.com/forums/924-931-...crosspost.html
Maybe try giving SpeedBump a PM, looks like he's running the same setup you're looking at.
