Possible to measure ring wear with head off?
I'm doing a head gasket on my 951 and I have some scoring on #3. I'm guessing it's from either:
a.) coolant in the cylinders from the bad head gasket
b.) metal shavings could have gotten in the cylinder when in a previous project I had to drill out an intake bolt.
c.) there was about 2 weeks I was not getting oil pressure for 5 seconds or so on startup from sticking OPRV (only used the car sparingly here)
All pistons have similar rock in all directions, this is only in the lower side of #3. Is it possible to use a feeler gauge to measure the distance from the piston to the cyl wall to make sure my ring is not completely worn?
