Going to put new strut inserts in. What else while I'm in there?
Old 04-02-2011, 10:42 AM
  #31
xschop
xschop's Avatar
If you have late offset control arms, the extra angle will wear out that OEM rubber bushing alot quicker than normal. BTDT.
Old 04-02-2011, 01:17 PM
  #32
CurtP
CurtP's Avatar
Yep, late offset. I noticed how much movement there is and have been concerned. Sending you a PM with some questions.
Old 04-03-2011, 10:48 AM
  #33
trouble8v
trouble8v's Avatar
Default Going to put new strut inserts in, What else while I'm in there
Hey xschop, Where can I get that 80A poly at??? I have an 87 944 N/A & I am definitely interested in that set up!!!!!! In fact I STILL have my original mounts layin around back when I replaced mine with the KLA Industries units
Old 04-03-2011, 10:54 AM
  #34
xschop
xschop's Avatar
It's 60A......80A would be too harsh of a ride.... I turned them on my lathe and Dawgz pointed out that the early mounts will fit a late car, I just fixed the strut angle interface by 4 degrees as the strut mount to spindle difference is 4 degrees between the late and early cars
Old 04-05-2011, 06:49 PM
  #35
trouble8v
trouble8v's Avatar
Hey xschop, How much to make me a set for my 1987 944 N/A, I'll separate my originals & have the housings powdercoated.
Old 04-05-2011, 07:27 PM
  #36
xschop
xschop's Avatar
PM sent....You need the Early mounts (pre-87) for a rebuild.
Some have removable lower bearing cups that contain the planar bearing and the 85-86 had them incorporated (vulcanized) into the rubber.
Quick Reply: Going to put new strut inserts in. What else while I'm in there?
