Fuse panel help
Fuse panel help
My '84 was sitting up for the past three years or so with a leaking sunroof. There was a lot of moisture in the car and the contacts for the lower fuse panel corroded.
In an effort to get the electrics working again, I decided it would be a great idea to pull the main fuse panel out of the car and clean the terminals for the fuses. What I didn't do was make a note of where all the wiring on the backside of the fuse panel goes. It's back in and the car is running fine, but there are still a couple of electrical issues. I replaced all of the wires by following the current flow diagram from the factory service manual, but there are a couple of wires still loose.
Could someone take a picture of the back of their fuse panel showing the wires in the "G" and "H" blocks?
