Anyone with a tiptronic 968?
If someone on the board has a 968 with the tiptronic, would you PM me please. I have a few questions, and a couple requests for you
Thank you,
Thank you,
Tips
Obviously you haven’t driven a tip at the limits. In a 968 they are basically 2 speed transmissions. 2nd and 3rd. That will keep you in 3500-5000rpms +. Try it. You will spend your time Throttle steering and lifting to rotate the rear end instead of shifting. It might change your mind about tips. 968 cab tips are becoming rarer by the day and more desirable. The were less than 600 imported between ‘92-95.
