wheel won't hold air? no not the tire, the wheel!
#31
Team Owner
this is not an uncommon issue with cast aluminum alloy rims. The tire needs to be removed . Usually they run the wheel around with a wire wheel on the inside where the bead sits to remove and corrosion and impurities.. Put some goop around to seal and throw the tire back on.
#36
iceman, thats the plan if i continue to have trouble... in fact these wheels need a paint job pretty bad so i might have them painted and clean the insides up really well anyways...
