Control Arm Bushing Removal Help
Im in the process of installing monoballs in my control arms. I was able to heat the metal parts and remove them, leaving the rubber. I burned the rubber away, and now I'm left with two metal sleeves which seem to be pressed in to the control arm from both sides. They are the same style sleeves that are in the trailing arms.
How do I remove these?
I just did this last night! I put some heat in the trailing arm with a propane torch then beat on them with a sledge hammer, alternated b/t a chisel and a screw driver. The sleeves were stubborn.
Not sure if there's an attachment that would do the job, but a slide hammer sounds like it would be incredibly useful for this. Sorry if that's unhelpful. good luck!
I have a pretty nice BFH that I will try...
Thanks for the advice guys, I just wanted to be sure that this was actually possible before I started beating it into submission.
I ended up cutting them in half by removing the blade from the hacksaw and feeding it through the hole then reattaching blade and cutting.
I also removed the balljoints, man those clips were a pain in the ***!
Press the new ones in with a C Clamp, or in the case of monoballs slide them in, and install the snap ring!
FWIW, I will be hosting a "how to" rebuild your late control arms clinic at my house in a week or so, as my 88 NA needs new ball joints, and I am currently waiting for a shipment of bushings...
You need to remove the metal in order to fit spherical bearings. But I guess you wouldn't if you are replacing the rubber only.
+1 to JKW, the hacksaw way is really easy, it took me about 5 minutes to get the second control arm done, after messing with the first one for an hour or so.
I also managed to put a nice gash next to my eye by pulling the grease gun off the ball joint grease fitting and smashing it into my face haha.
OUCH... cant say I have ever done that with a grease gun!
The bushing is made of three pieces. An outer metal sleeve that needs to be pressed in separately, a rubber bushing and an inner metal sleeve. If you are replacing stock bushing and the outer bushing is already in so tight it needs to be cut out, why replace it?
Of course I thought of this after cutting them out. If you freeze the bushings the inner rubber can easily be separated from the outer liner. Then you can send me one of your unused liners as I gimped one of mine putting it in.
