Anyone have a rear wiper arm?
I assumed my broken rear wiper was a stripped gear. After picking up a new motor, I realized upon disassembly that it's the arm itself that is stripped... splines completely gone. There are no NOS arms available anywhere (Pelican, Sunset, Porsche, etc). Does anyone have one with the splines intect that they would part with?
For a 88 '951, but I think they were the same for the whole series. Part # 477.955.409A.
Also, this means I have a spare, functioning motor if anyone is in need. Part #s:
477.955.713A (motor)
944.628.071.02 (mounting plate)
477.955.737A (cap)
and all of the spacers, washers and nuts
477.955.737A (cap)
I had this problem too -- so I drilled a hole in the wiper arm where it mounts on the motor shaft. I then put a screw in the hole I drilled and tightened it against the shaft. The wiper arm is made of soft metal, so you need to be careful not to screw down too hard -- I assume it would strip easily.
Anyway, it's been working fine since.
Anthony
'84 944
Anthony
'84 944
