Rough Idle Fix
Rough Idle Fix
So I have had this Rough idle (and very slight misfire sometimes) especially when the engine is cold...
This weekend I Replace all the Vacuum Lines, Cleaned the ISV, Installed New AOS, Installed a New End Cap O-Ring in the Upper Balance Shaft Housing, and Clean a bunch of ground connections...
Start her up,,,, and Rough Idle!
Decided to replace sparkplugs ( I had Autolite Xtreme Performance Iridium Spark Plug with the pointy tip) and bought some Bosch Platinums.. When installing the Bosch Plugs I notice the Gap was tiny when compared to the plugs i was removing...
So i checked the gap on both plugs, and the plugs I was removing were like .045!! (should be like .028-.032)
Anyway install the New Plugs with the Correct Gap; Car runs So much Better and the Idle is So Much Smoother!
A Simple Check for Rough Idle/Misfire = Check Your Spark Plugs!!
Yea, you might be on to something... I did notice that at first my car idle and ran great... But last night i went out for dinner, and it seemed to idle rough again...
I will pull the plugs and check them out... and probably pick up some Coppers
Yea, Fuel Filter is brand new.
If the FPR failed, It seems like the car would run better when cold; I read that when the FPR fails; the diaphragm inside cracks, and actually allows gas to get into the vacuum lines; this causes the car to run rich. Much Like a Choke on a carburetor; So when its cold the engine would start easy, but when warm it would be too rich...
Thanks for the input, i will update this post with my findings!
I am wondering if maybe my i am getting too much oil in the cylinders and causing the plugs to foul... I will pull the new plugs out, and look at them,.. But based on what i read i think i will pickup some Copper Plugs either way... A lot of complaints about Platinums in our cars (your were right)
