Separating seat back from base
Recovering the seats. How does this **** assembly come off?
IE., how to separate back of seat from base?
I have the other side apart after loosening screw.
Jeff
1983 944 N/A
Jeff
1983 944 N/A
Its actually really simple. I just did my seats. You have to pop the plastic piece off of the large ****. There are 4 indentations that you can see. Use a small flat head screwdriver to pop it off. Once you have that off, you will see how the **** is held onto the seat. Use a flat head screwdriver again and push it against the metal mechanism inside the ****. Then turn the **** with your hand to free it up. It will make more sense once you see it. Then you can pull the large plastic cover off and there are two bolts behind it that hold the seat back on. Take those off and disconnect the cable that runs from the seat back adjustment.
It's really easy to do once you get it apart and look at it.
