Weird Crankshaft question
Take it to a machine shop, and have them weld it and regrind it to spec.
Depending on the damage, it usually doesn't cost very much. Probably more than a cost of another crank...but not as much as the used crank shipped to you.
So now that I've had time to sleep on this, my other concern is HOW this happened. It doesn't appear to be oil starvation, because the thrust bearing is
severely worn ONLY on one side (the front side). The rest show what I would call normal wear....no other damage inside that I can see.
Pictures are not great....but you can clearly see the damage on the front side of the thrust bearing. Unfortunately, the crank is really bad.
You can actually feel a ridge in the journal where the bearing was digging in.
Once I get the crank out of the block, I'll take a few pics of it.
