Engine compartment insulation falling apart. IDEAS?
So everytime I open the hood there is foam or whatever it is all over the place.
I see you can buy replacements from Pelican, but I'm not sure that the best use of the $100 I have in my pocket. I'd rather invest in my retirement.
SO has anyone ever removed the insulation? Is it really loud after? Does it look horible?
Looking for comment on this.
Merci
Merci
You can remove it without ill effect. The later cars actually came without it from the factory. If your car is a turbo, you may see some damage to the paint on the hood over time due to heat. This is a bigger issue on cars that are tracked.
Remove it and don't look back... However there are many in the camp of replacing it with an upgraded material..
I have first hand knowledge of at least 1 car that almost burned to the ground, but is now returned to operation, the hood liners saved the paint during a complete engine fire!
They are not required for the car.. but I consider them to be like a gun.. it is better to have them and never need them, than need them and not have them!
yeah I put some in my 1990 s2 , none from factory.
the paint on the hood above the exhaust manifold...if you look really close with a halogen light ( I was detailing it ) ...I could see these linear indications, that sealed it for me. car only had 83000 mi @ the time
I bought the ones from automotion, with the reflective foil looking stuff. fit like a charm.
Merci
Merci
James
