RPM drops below normal idle.
When I let go of the throttle after revving the engine the idle drops below normal RPM for a second.
Normal RPM at idle is 950, when returning after revving to idle it drops for a moment to 850-900 RPM then continues to idle at 950 RPM again. Is this normal, or shouldn't the car drop below idle?
I have adjusted my idle manually with the screw next to the throttle house. I recently rebuild the engine. Do I need to perform special procedures to set it up properly again? The car is a '86 944 N/A.
<a href="http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic;f=15;t=015702" target="_blank">Check out this link</a>, my rpms used to drop to about 2-300 then come back up, this fixed it.
