Smog Help...
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
So went to get my car smogged the other day and it failed. /: But it's not all bad. The only major catagory it failed was NO(PPM). So my question is, has anyone had a similar situation and what did you do to pass? Here's the exact results in the NO test.
15MPH-MAX(ALLOWED):795, MY RESULT:1093
25MPH-MAX(ALLOWED):676, MY RESULT:1119
Thanks in advance for any/all help.
Proprietoristicly Refined
Rather than making a foolish guess, maybe these links...
https://rennlist.com/forums/924-931-...d-ca-smog.html
https://rennlist.com/forums/924-931-...emissions.html
GL
John
GL
John
Hey Man
You need a 'real' cat, not one of those generics from several years ago that last for one testing. Talk to the owner at Specialized Exhaust on Grantline/99. I went through the NOx issues on three cars in the last 18 months HC was OK, each one passed with flying colors after a new certified cat was installed. He does great work, it will cost about $200. Have clean oil, clean plugs, and make sure the cat is very hot before testing. Good Luck
Ok so researching some other threads I came across a reference to "E85"... what is that and will it actually work? Also thanks about the cat advice already looking into running a new one. Also how much would a new O2 sensor cost me.
E85
http://en.wikipedia.org/wiki/E85
O2 Sensor
http://www.frwilk.com/the944/oxygen.htm
DO NOT SOLDER the wires...
Get a Bosch or better....the cheap/generic do not have the quality materials (Platinum) to last.
GL
John
O2 Sensor
GL
John
Small Business Partner
NOx is a result of high combustion temps... retarding ignition timing will help, so will a bit of E85...
What was all your #s so we can see how close you are on the other categories?
you can try putting some high octane unleaded 104 race gas and that should bring the nox down to just barely passing ( could be a result of carbon in you combustion chamber, or using bad gas, or just an old or cheap cat, can you post all of your resultS? co2 o2 nox hc and co at both speeds, I can get an overall lambda reading with the results and point you in the right direction. If your 02 sensor is faulty, you sometimes have multiple fail results and or your CO readings would be around 0 or extemely lean ( which will pass , but is an indicator of a lean mixture.)
nox is a result of too much air (running lean), detonation, pinging, incorrect timing, wrong octane gas, bad cat, bad egr (not for us), bad o2 sensor if stuck rich ( computer thinks there is too much fuel, so it will lean out the mixture) , and sometimes a bad VAF or MAF. Of course a bad cat, or to much carbon in the cc chamber is also very likley on an older car. A vacuume leak will draw in more air, and if your ECM reads the difference of the added air , it will add fuel to compensate and you will run a richer mixture, and have much less nox.
lean conditions = higher nox and o2
rich conditions = higher hc and co and less 02
an easy way to to check if your cat is still functioning via test results is : for both speeds, add up co2 and 02 % ( if the totals are 14.5-15.9%, your cat is oxidizing and reducing and your problem is not cat related) so at 15 mph if you got a co2 reading of 13.8% and an 02 reading of 1% or slightly higher, your cat is working) Basically to sum it up, if your co2 and o2 add up to 15% ish, you have good overall engine efficiency and a good cat. I can get way more thourough, but these are just some basic guidelines,
I am a licensed Enhanced area certified smog tech here in the SF bay area.
15MPH-2840RPM-14.34(CO2%)-0.23(O2%)
HC(PPM):MAX:95-MY RESULT:75
CO%:MAX:0.58-MY RESULT:0.23
NO(PPM):MAX:795-MY RESULT:1093
25MPH-2832-14.40(CO2%)-0.19(O2%)
HC(PPM):MAX:77-MY RESULT:63
CO%:MAX:0.44-MY RESULT:0.18
NO(PPM):MAX:676-MY RESULT:1119
If it is set to stock (position 0), then try either position 4, or 5. Both 4 & t will lower NOx, but position 5 will also increase HC... You have a little bit of wiggle room with HC.
