968 Crankshaft Standared size specs
I have searched and searched and cant find the answers.
What are the size specs for a STD/STD crankshaft from a 968?
Same as a 944 or 951. Only difference is the stroke length. 88mm (well, 87.8mm)
I don't know the actual specs, but I suspect they will be easier for you to find.
That's why the 968 crank can be used in the 944 block to make a 2.8L
944/951 specs should be easier to find.
