I need some head
Old 05-29-2003, 01:59 AM
Bri Bro
Bri Bro's Avatar
Post
Just remove the 6 bolts that connect the header to the exhaust, loosen the head studs, and remove the head with the headers still attached. If you try to take out the studs from the head, odds are that one or more will break off.
Old 05-29-2003, 02:02 AM
badcoupe
badcoupe's Avatar
Post
Anyone ever have a srdii radius valve job done? My tfs heads on the race car as well as the head on my big midget motor (built by speedway engine development owner, they build the chevy IRL motors) have had the seats radiused instead of an angular valve job.
Old 05-29-2003, 02:05 AM
Perry 951
Perry 951's Avatar
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by beab951:
<strong>Just remove the 6 bolts that connect the header to the exhaust, loosen the head studs, and remove the head with the headers still attached. If you try to take out the studs from the head, odds are that one or more will break off.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Brian, you read my mind.. or I read yours.. something like that. I see a lot of posts about head removal being such a bitch, but most people pull the head without the headers attached. This is much easier folks!
Great tip Brian!! <img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
Old 05-29-2003, 02:37 AM
Bri Bro
Bri Bro's Avatar
Post
Perry, should we tell nickhance that 4 of the bolts can be removed in your sleep but the other two require several swivel extensions (broke at least two so far) and that they are a PAIN to get to? Still the path of least resistance.
Tip: Spray the bolts with oil several hours before you remove them. Better yet, get a muffler shop to remove only these two bolts while the car is still running.
Old 05-29-2003, 03:58 AM
nickhance
nickhance's Avatar
Post
nah, the head is already out and ready to go, the headers are disconnected, but the studs are still in the head.
Should I remove the studs before taking the head to get serviced?
Old 05-29-2003, 07:02 AM
Legoland951
Legoland951's Avatar
Post
Looking at the title, I am thinking don't we all need it every once in a while? Of course we are talking about when the timing belt breaks right? Shave the head will give you more compression and power while you have that thing at the machine shop. If I buy the car tomorrow, I will be doing a head replacement too.....
Old 05-29-2003, 12:18 PM
Bri Bro
Bri Bro's Avatar
Post
Leave them in.
Old 05-29-2003, 12:27 PM
Perry 951
Perry 951's Avatar
Post
Unless they need to be replaced for a reason, leave them in. Chances are that you will snap at least one off if you try and pull them.
Quick Reply: I need some head
