Door Lock Jammed!
Door Lock Jammed!
Hey guys... I locked my car door and now my drivers side door won't un-lock! I have power locks. Using the key just unlocks and locks the passenger side door, the switch in the car does the same and physically pulling up on the lock doesn't work... Any suggestions on how to fix this? Thanks a lot for any help you all can give!
-Noah Sanders <img src="confused.gif" border="0">
Well apparently i didn't play with it quite enough before I posted my question It's working fine now, it just took some elbow grease to get it going again! Sorry about that!
I had to clean and lube my standard doorlocks due to some sticking. It required pulling the door panels, but was a fairly straightforward job. They now work smoothly.
