944 Window Regulator Roller
Howdy Howdy,
I have been searching for a few days now without success for window regulator rollers. These are the little plastic caps that fit over the ball joint on the window regulator scissor arm, and slide in the metal channel inside the door. Without it, my window falls down at an angle whenever rolling the window down. I have a 1989 944 S2.
I can't seem to find any new ones. I may resort to 944ecology, as I've heard others have been able to get some from there, but I'd like to get ahold of a new one if possible.
OR... is there another way to fix this without needing new rollers? I've read of one person using a combination of screws, loctite and washers to come to the same result. Any info would be much appreciated, thanks.
