Expansion Valve Replacement
Does anyone have a procedure or tips for replacing the expansion valve on a 86 944/51? I've heard three different opinions, (dash removal, through the blower motor, through the glove box) but not from anyone who has done it themselves. Most have described their mechanics method or the workshop manual's instructions. Which is the easiest method? I plan to write up the procedure for future rennlisters so any tips would be appreciated.
Hey Jeremy,
Were you able to get a write-up going for the replacement of the expansion vavle? Is it as easy as removing the blower motor?
Also, does anyone know the amount of oil the entire A/C system requires?
Thanks...
Thanks...
Originally posted by sm
Hey Jeremy,
Thanks...
Hey Jeremy,
Thanks...
The 944's call for just over 2 oz of oil but I don't trust that #. I don't know if I've ever seen a system that holds less then 4.
