New to the site
New to the site
I have just migrated over to this site. Hopefully some guidance can be given. First of all I have browsed the search feature and will continue to do so in researching the issue I have with my 1982 924 NA. Am not getting spark or fuel and been troubleshooting it for a year off and on. The fuel pump relay has been replaced. The WUR has been replaced. Battery fully charged. Both sides of the coil show 12V when key is on. Pin 4 shows 12 Volts on the ignition module. The dizzy has been rebuilt, The ignition module has been replaced. Fuel pumps test out good when relay is bypassed. Get fuel when hot wired from battery to the negative side of coil. It has the TCI-H ignition system. Pins H+ and H- show the correct voltage to the dizzy and the ignition switch has been replaced. Are there any ideas of what could be going on?
