new s2 wow!!!!!!crazzy!!
wow I just get delivery of my new s2 91 coupe, the car is one owner and is dealer maintain all his life I wit 3 week to delivery company show with it , any way have soem little tiny fault with your help I'm gona takcle them, but jsut blow my mind owner put 5k dollares in 2009 in new clutch new brakes new belts! at dealer,,
reading here !!(one of faults is check engine light on) paper from dealer porsche said scan and chack not faults found 280$!!!!!!!thats crazy!!! if the dealer coudn't find why the check eingine lights is on how I will fix that? car runs exelletnt not issus oil pressuer is fine !!
the 2 fault is rear wiper not working
the 3 central lock not working!
the 4 tail light not working!
the 5 dome light not working I diecovery wire snp off of the rearhatc support so want tackle that tomorrow hope fix dome light!!!!
but wow ownwer give me 15k in papaer receips since 1992!! i pay real cheap for it!!!I need all hlep from you guys!!!thanks
Sorry! I will slow down and use the spelling botton!!
I will post pic tomorrow, after clean it up, is all original condition almost too good , I bought set 17s 5 spokes new pirrelli ,I can wit to try in it - will change look of it ,, but really wants to fix the electrical issues and see , thanks for help!
abot price lest say I paid what usually you pay for 924
Top up the oil level and light will probably turn off.
I wouldn't be surprised if dealership missed that.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Welcome to RL and congratulations on your new car.
I would suggest getting familiar with the RL search function. Many questions have been asked and answered before.
If you can't find your answer, then perhaps one thread per problem might be easier to manage.
Check the oil level as stated, are any other warning lights on? If not, there may be a bulb burnt out in the cluster.
Does the motor run when the switch is turned on? If so check the nut holding the arm in place.
Does it only not work when the drivers door is unlocked? Try again from the passenger door, and try the switch in the dash. If only from the drivers door, it may be the plastick linkage in the door.
Which one, or all of them?
If only the rear light that isn't working, the wire is a good place to start.
