Fule injectors?
Lifetime Member
Lifetime Member
Fule injectors?
What is the diff between the turbo and the na fuel injectors for an 87 944. Is ther actuall a diff or is it an excuse to charge more because some one has a turbo. Or better yet will the turbo versions work in an NA? <img src="graemlins/bigok.gif" border="0" alt="[thumbsup]" />
The na are peak and hold injector at 2.5-2.8ohms and rated at 23#/hr.
The turbo are an odd impedence as they are about 4.8ohm, above the P&H range and below the Saturated 12-16ohm type. They are rated at 37#/hr
They do not work in an n/a car as I have tried, but it may have just been my car. Most guys here that are running aftermarket injectors are using P&H 2.5-2.8ohm Siemens or Bosch, but there are others avaiable. I will be using a set of ACCEL 55# which happens to be Siemens (got a great deal on them!!).
