UPDATED: 944/968/951/M030/Turbo Cup Shocks, Struts, Springs & Susp. Parts
All for late offset '87+
SHOCKS:
*Koni rear DOUBLE ADJUSTABLE coil over Porsche Motorsport shocks. Used, but unused since tested good by PSI at Sears Point Raceway [dyno sheet available]. These shocks have factory 951 part numbers stamped into them -they were from the Escort series days. No spring perches. Has offset mounting eyes so uses standard mounting bolts. VERY RARE. Where else can you buy a pair of double adjustable 944/968 shocks for $450 ? SOLD
*Bilstein Turbo Cup rear coil over shocks. Real deal Porsche Motorsport shocks with 951 part numbers. Need rebuild (estimated at $65 ea. at Bilstein USA). Rebuild them to your valving/spring specs. Match these with the Bistein front strut below for upgraded Turbo Cup suspension. $250
STRUTS:
*Bilstein Turbo Cup left front Strut [Gold], this is brand new and has never been installed. Valved 600/180. Lindsey sells this for $495. My price $300.
*Standard 944S2 struts w/116K miles. Right side needs insert. $25 SOLD
SPRINGS:
*968 M030 Rear Barrel Springs. Two green dot. New, never used but paint has some nicks from rolling around in a box. I had them tested at The Racer's Group at Sears Point and they measure 120 lbs./in. $60/pair.
*944S2 front springs, two purple dot - stiffer than std. turbo. $30/pair.
Suspension:
*Front 944 M030 A-arms w/ caster mounts in good condtion. $120/pair. SOLD
*Rear M030 suspension mounts. $40
*Front strut 951 air ducts. $20
Please PM with any questions and give email address if you want Pics. All prices are plus shipping from Napa, CA 94558.
Thanks! John
SHOCKS:
STRUTS:
SPRINGS:
Suspension:
Thanks! John
