power steering high pressure hose replacement
I have a 1991 944 S2. I can see the high pressure hose from my power steering pump to my rack leaking badly. Aside from buying the hose itself are there any special gaskets or seals that I need to replace this? Anyone have any info on this I should know before i start?
Team Owner
From: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
i have a brand new hose but it's for a 968. don't know why i'd be needing it, cuz i went in there and everything leaks (like i expected different ?) anyway... for now i'll try to live with it cuz it's a slow leak.
The high pressure line for the 968 is the same for the 944 S and S2.
Will I need anything else though? Are the banjo bolts the cause of the leak? Should these be replaced as well? Do you guys use teflon tape on the threads (above the hole in the banjo bolt of course.... if there are threads above the hole, I haven't looked yet.)
On my 85 BMW 535i, I took the hoses to a shop that just rebuilds hydraulic hoses. While I was there, a guy came in with a hose as thick as my arm.
They replace the hose, and keep the (metal) hardware. no leaks. I expect its way cheaper than new parts.
Regards,
doug
Waterloo, Ontario Canada, eh
86 951 (http://www.pcaucr.org/index.php/visu...egory&catid=61)
01 E320 (W210) 4-matic Wagon (http://www.benzworld.org/forums/w210...body-do-2.html)
00 540i-6 (http://forums.bimmerforums.com/forum...hp?albumid=976)
94 855 turbo Wagon (sold in 09)
85 535i-5 (sold in 07)
76 300D (sold in 92)
83 944 (sold in 86)
I apparently only buy cars designated by numbers
Regards,
doug
83 944 (sold in 86)
