Wipers not pressing on the windshield hard enough
Old 11-05-2010, 03:56 PM
ExitWound
ExitWound's Avatar
what about Wiper Snuggies?? Think it'll help?
Old 11-06-2010, 12:01 AM
FRporscheman
FRporscheman's Avatar
Is that the robe you wear backwards?
Old 11-06-2010, 05:29 AM
safulop
safulop's Avatar
Originally Posted by FRporscheman
Looking at your pic again, I notice the arms bend up and then bend straight again. I recently R&R'ed my 968's wipers and they don't have that bend. Maybe if you just straighten them out it will help (which would basically achieve the same thing as my last post). Good luck.
+1 my 1985 wiper arms do not have those bends. You could buy new wiper arms, I don't think they are expensive. They should have a gentle curve with no sharp angles or bends.
Old 11-06-2010, 06:01 AM
FRporscheman
I bought '86 wiper arms at pick n pull for about $5 each IIRC.
Old 11-06-2010, 11:27 AM
F18Rep
F18Rep's Avatar
I have a similar (not as bad) problem - I think maybe the springs are just weak from age/fatigue. Its on my list to find a fix because the wipers just don't work very well, especially in winter weather....Bruce
Old 11-07-2010, 08:56 AM
ExitWound
ExitWound's Avatar
Thanks for all the responses (serious and non).
Old 01-12-2014, 04:14 PM
Audioeditor
Audioeditor's Avatar
Default Wipers missing middle part of winshield
We've had both windshields in both our fords replaced due to hail damage. That's when they both started missing large patches on the drivers side. I've tried two sets of very expensive blades from Auto-Zone but nothing helps. My wife got tired of hers and drove into Firestone where a very nice mechanic did some bending on the actual arm that holds the blade and now hers work fine. I wasn't with her so I didn't see him do it, but I'm convinced that's what needs to be done to mine as well.
That's really strong metal so it may take a couple of pairs of vice grips to do it but at least that makes sense. I thought maybe the replacement windshields weren't formed correctly and might have a miniscule depression in the middle. That still might be the case since they worked fine before the replacements, but bending should make up for that unless it's a severe malformation in the glass.
Old 01-12-2014, 04:26 PM
Arominus
Arominus's Avatar
Bend the arms just a little bit that should give you more contact pressure.
Edit, Damn I fell for the necro thread.
Old 01-12-2014, 04:41 PM
Voith
Voith's Avatar
If you have early wiper arms with one spring, swap them for late 2 spring arms. If this doesn't help, something else is bent.
Old 01-12-2014, 10:31 PM
OnlineAlias
OnlineAlias's Avatar
Necro thread...that made me laugh.
Old 10-18-2018, 01:24 PM
Michael D River
Michael D River's Avatar
Smile Wipers not pressing on the windshield hard enough SOLVED
Pull the wiper blade away from the windshield allowing access to that hinge that makes the blade come out from the windshield and spray a little bit of silicone spray on the hinge at the base of the wiper arm...If that hinge has too much oxidation then the spring will not be able to do its job in pressing the wiper on the windshield hard enough to wipe the windshield clean.
God Bless <3
Old 10-18-2018, 10:47 PM
pauldvazquez
pauldvazquez's Avatar
I had the same problem, even after replacing the blades. I finally figured out that the nuts securing the arms to the motor shaft were loose. Once I tightened them I had full surface contact throughout the arc.
Quick Reply: Wipers not pressing on the windshield hard enough
