Re-Keying all my locks
Okay... I need to rekey all the locks in my car. Would it suffice to just rearrange the pins and have a key made to match?
I need to do this for the doors, hatch, gas cap, glove box and starter/steering.
removing the tumblers from the doors, hatch and glove box appear simple enough... the steering column and gas cap appear to be a bit more difficult. Anyone done these?
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Gas cap is the easiest of them all just pull the red part off and then put the key in and turn and it's slides right out. I notice that a lot of the caps have a piece down there that breaks often so check that too or the cap won't lock.
Cheers
Mike
Cheers
Mike
I believe the wafers can be rearranged for the doors, hatch, gas cap and glove box. A qualified locksmith should be able to cut you the new key with a code cutter/machine. I am not sure about the ignition switch being rekeyed though.
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
Hi Miles, The whole Ignition Assembly is held onto the Steering shaft by two halves that were bolted together with two torque bolts that the heads are sheared off from the bottom. Use a cut off wheel in a Dremel Tool to cut a slot across the top (end) of the bolts and turn them out with a stubby screw driver. I got the inspection mirror out and looked at the back side of the electrical switch module. There is a plug with all the wires that has to be pulled off the module, got that pulled (careful you don't pull out the wires). While the gage cluster was out I replaced all the light bulbs. The gage cluster trim has two hidden screws, one above and one below the trip reset button at the vent edge. I hope this helps if you have to use it. The link below gives the module wire lay out for the plug. The second link will show what the Ignition Assembly looks like. The third link shows where you have to drill in order to remove the Ignition Lock Cylinder.
http://forums.pelicanparts.com/porsc...87-944-na.html
http://nasaforums.com/viewtopic.php?f=40&t=20345
http://www.the944.com/key.htm
Cheers,
Larry
Cheers,
Larry
