Are 951 turn-signal lens gaskets available?
Just checking my turn-signal bulb to see why the front running light isn't working, and the gasket looks like it disintegrated 10 years ago. There's a lot of corrosion in the socket, but I got the bulb working again.
Two questions: Does anyone stock the gasket, or do I have to buy a whole new lens assembly?
Also, at first I thought the bulb was a good old 1157, but they have an extra contact at the back. Are these available at most autoparts stores?
Hmmmm. I checked with the dealer and the parts guy says there's no gasket, the lens goes right onto the housing. Are you sure you're not thinking of the fog light lens?
I think you're probably right, as there was something that looked like it had been part of a rubber gasket in beside the lens.
