CV removal: STUCK cheeseheads
The new CV was 30 ft lbs and they came right out. I used blue loctite.
The ones installed in 1986 by angry Germans required a bit more torque. They sounded like they were scraping, as if the threads were dry. The grease that was on the CV boot appears to have come from inside the CV joint and leaked all the way out from the back. That must've taken a while, or a lot of runs down the back straight at the glen.
How much play in the CV is too much? guess I can compare the two since the passenger side is brandee newdee.
I now have the drivers side swing arm off the car. I need a nap.
Regards,
doug
Waterloo, Ontario Canada, eh
86 951 (http://www.pcaucr.org/index.php/visu...egory&catid=61)
01 E320 (W210) 4matic Wagon (http://www.benzworld.org/forums/w210...body-do-2.html)
00 540i-6 (http://forums.bimmerforums.com/forum...3&d=1283457963)
94 855 turbo Wagon (sold in 09)
85 535i-5 (sold in 07)
76 300D (sold in 92)
83 944 (sold in 86)
I apparently only buy cars designated by numbers
Regards,
doug
83 944 (sold in 86)
