CV Bolts worked their way out???
Old 05-12-2003, 02:01 PM
Dales944
Dales944's Avatar
Post CV Bolts worked their way out???
15 months ago, I changed a CV joint (outer pass side). I am absolutely POSITIVE I torqued the bolts to the spec in the Haynes manual. Today, I was poking around under the car (boring lunch hour) and saw that two bolts seem to have loosened all the way out - the only thing holding them there is the CV boot ridge.
So, my question is... Is this common? Was I supposed to use some form of thread-lock? What gives?
TIA,
Dale.
Old 05-12-2003, 02:05 PM
Peckster
Peckster's Avatar
Post
It is common. I think some people use new bolts or nuts?
Hasn't happened to me though.
Old 05-12-2003, 02:07 PM
Dave951M
Dave951M's Avatar
Post
Yes it can happen especially if some of the grease got into the threads while you were putting the bolts back in. That's why I recommend going back in and checking them after a couple thousand miles. I check mine before every autox.
Old 05-12-2003, 03:30 PM
wa944
wa944's Avatar
Post
I've heard that the bolts are the torque to yeild type, requiring replacement upon removal. Is anyone able to back me up on this, or am I just blowing smoke?
Old 05-12-2003, 05:43 PM
M758
M758's Avatar
Post
This is common. Always use new ones, use loctite & clean the threads.
And still inspect.
Old 05-12-2003, 06:24 PM
Red1
Red1's Avatar
Post
I didn't know it was common. (Now I'll be paranoid until I get home and check them.)
Good post.
Old 05-12-2003, 08:46 PM
Dales944
Dales944's Avatar
Post
Thanks everyone for your insights. New bolts came with my kit, but I do know some moly made its way into the holes while I was packing.
Anyway, when I got it up to tighten them - two were completely out (as I stated above), two were loose enough to turn with my fingers, and two were still tight.
Scary. I'll never go more than a month without torquing them again!
Thanks again.
Old 05-12-2003, 08:49 PM
nixwiz
nixwiz's Avatar
Post
Dale, I'm curious, did you notice any noise or vibration due to the loose bolts?
Old 05-12-2003, 08:58 PM
Dales944
Dales944's Avatar
Post
Nixwiz - it's hard to notice anything on top of the regular noise and vibration! But really, no - I had no clue until I peeked underneath for a different purpose (trying to see how much of my exhaust I could remove).
Old 05-12-2003, 09:27 PM
Bob S. 1984 Silver
Bob S. 1984 Silver's Avatar
Post
You can also drill a hole (small) through the head of each one, and use safety wire to prevent them from coming loose.
Quick Reply: CV Bolts worked their way out???
