Door removal, which is easiest way???
Did the search thing and seems like there are 3 options.
Option 1....cut the wires.
Option 2....disconnect the plugs on the door side and pull them through the hole. From what I sam today this one would be a HUGE PITA and it would not solve one of the three problems I hope to solve by swapping doors from my parts car to my driver.
Option 3....disconnect the wire at the harness end. Cannot find a good guide how to do this.
So, what have you tried? What works best? I am swappign the doors around because of three things:
1. The script door handle on my drivers side is missing the latch pull anyway.
2. The window switch on my driver's side door is working sometimes, sometimes not. Took it apart, taped together and spaced with pieces of cardboard. It's gotta go.
3. I was going to use the door panels from the parts car anyway.
So ALL this lead me to decide the easiest fix was to swap out doors both sides, everything is easy EXCEPT the darn wires.
Any advice much appreciated. Any pics GREATLY appreciated.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
michael
michael
