I've lost my boost!!
i've had my boost turned down to about 10 psi with my reliaboost, and went to try and turn it up a little by shortening the reliaboost and I can't get above about 10.5ish psi. I screwed the controller all the way in, so there were no more threads showing, and it still wouldn't even hit eleven. I saw 17 psi just about a month ago on the same setup. Could my wastegate go bad that quick? Vacuum leak? Any suggestions?
Coolhand -
Chances are, you're looking at a vacuum leak - but under pressure only if you're not having idle problems too.
Easiest thing to find though. Change your fuel filter, and cut the old one in half with a hacksaw. You'll find that one of the fittings comes out on the old filter, and that a standard air chuck for an air compressor tool fits in well. Also - a tire valve fits in well too.
Pressurize the intake to about 7ish PSI, and spray soapy water on all the vacuum connections. You'll find EVERY leak.
HTH!
HTH!
Coolhand -
Oh yeah... The new fuel filter half fits in perfactly into the rubber J boot on your car, in place of the air flow meter. (DUH... Forgot to tell you where to put your new cool tool....)
HTH!
HTH!
Thanks for that tip - I actually found the leak without doing it, it was a tear in one of the hoses. I fixed it and the boost came back fine.. for about 5 seconds. I downshifted into second, and I only got about 4 psi and that's all it would put out. Will a small leak drop you 10 psi, or would this only be caused by a big one that i should see? I searched every connection I could find, and I couldn't see anything. Guess I'll do the fuel filter trick...
