What am i doing wrong here... (now stuck on bellhousing)
as far as the bell housing, i made a short socket for the top bolt (19mm iirc)
i also notched the bell housing so i could set the sensors and put the bell housing on without removing them. in the future i am sure it may pay off.
yep, one of the first things I did. They were a bit tricky but I just took my time wiggling thing around up and down till they came out.
A u-joint-adapter and a few extensions did the trick on the tricky bolt.
Although I can't get the shaft out for the release, i'm literally ready to just pull the bellhousing off, but it refuses to move because of the shaft. Is there not a way to get it out in one big unit? I'm guessing not.
Any tricks on that shaft? I almost bought a slidehammer but couldn't find any that would fit in the area.
i eventually found that the bearings in the fork had seized and the shaft was badly galled. the threaded rod/hammer method was required (along with a new shaft)
I found a long bolt, slipped a small wrench (like 11mm) over the end of it and then threaded it in. Then I pried on the wrench against something solid (get creative, use a prybar for stabilization, etc) and it worked out.
