wind noise from drivers side door
maybe its going on with the passenger side too but since i sit on the drivers side.. when im driving with the stereo off and going over 50-60 mph i hear a wind noise coming from the back of the drivers door.. like if a window was cracked a bit but not that bad.. but still.. is that just the air passing through the door vents or is that normal or is that an air leak or something? the rubber on the door looks fine.. it closes fine.. all solid.. hmm i dunno?
see if the noise is coming from the drivers side mirror by doing this: drive like you said and listed for the noise, then when hearing the noise fold in your side mirror housing towards the door, see if the noise goes away or not. if so then the side mirror base piece is missing a white plastic piece that is inserted in there to prevent wind noise, sometime after removing the side mirror assemble people dont remember to put it back it, but the parts listings show that it is supposed to be there, see if that fixes it
