Motor Mounts to blame??
I am getting a vibration that rattles the driver's window when I put the car into gear and take off. Idle is kinda rough too, even after my tune up (plugs, wires, cap, rotor). The engine sounds great at speed, but I am guessing the roughness is being caused by engine mount(s) that are shot. They are the originals...My mechanic said they were fine a few months back...but I hear they should be replaced at least every 36k miles.
Should I bring her in??
I love Ninjas Sooo much...
The main symptom is vibration at idle, as RPMs increase, the vibration goes away. Check the passanger side first - heat and leaking power steering fluid affect the integratity of the motor mount. In my case, passanger side was shot, driver's was fine. I bought two new ones from Pelican Parts - an aftermarket set that does not have hydrolics inside. They are a little stiffer, but not by much, definitely livable for half the price.
Thanks.
Thanks.
Spoke with my mechanic...he says he remembers seeing that they were original mounts, so if I am getting the tell-tale signs, I should replace em.
He said he will put in the Turbo mounts, for $550. Is that on the high side, or about right for Porsche parts plus labor??
Seems every other repair is a $500 affair! Welcome to the club, I know, I know.
Shhhh...don't tell the wife!
I just, this morning in fact, picked up my car from my wrench after having both mounts and cam/balnce belts all for $650.
The mount job for a Turbo is more time consuming as well.
I would say a bit high.
The mounts are $55-100 each depending on which ones and it should be a 3-4 hour job for a NA.
When I had them done on my old NA I think it ran $350 or so.
