Skip, Tom Pultz, M030 Sway people...
![Arrow](https://rennlist.com/forums/images/icons/icon2.gif)
I ordered the four donut bushings for the front swaybar based on the part number on T. Pultz's (sp?) website. They don't look like the ones currently on the car, so I was wondering if there's a part number mix up some where? The bushings I received look taller and smaller in diameter, sort of like a .75 inch piece of hotdog (sorry, couldn't think of a better example). They do have the same PN as on T.P.'s website. Do they expand to the "donut" shape when installed?
Thanks!
Thanks!
This is for the 30mm 968 MO30 front bar correct? If so, when I installed on my car, these looked exactly like the previous bushings, but had and increased inner diameter to allow for the larger front bar.
HTH,
HTH,
You're making me hungry - donuts and hotdogs - yumm!
![](http://boards.rennlist.com/upload/late_sway_bush.jpg)
#8 is what I assume you are referring to? Carries part# 951.343.795.01
#7 - 951.343.793.31 (for 968 M030 bar)
#4 - 951.343.794.05 (for 968 M030 bar)
Good Luck!
Good Luck!
Lifetime Member
Lifetime Member
[quote]Originally posted by sm:
<strong>The bushings I received look taller and smaller in diameter</strong><hr></blockquote>After installation they'll look a lot shorter and fatter... just like most women in the US
Thanks guys! The bushings I received from Paragon do indeed look like those - #8. I guess I was looking at part #5 and thought they were the bushings...
Tom - you saying after you screw 'em in they'll be shorter and fatter? I'm talking about the bushings <img src="graemlins/roflmao.gif" border="0" alt="[hiha]" />
