1986 turbo brakes on early N/A
will the CALIPERS (and i mean calipers only) directly bolt from a 1986 turbo (early offset) to the 1985.5 N/A (early offset) ???
if not, what parts IE: spindle, rotors, blah blah
do i need to get
thanks alot,
SHAUN
do i need to get
thanks alot,
SHAUN
uh.. check out this thread <a href="http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic&f=15&t=005204" target="_blank">N/A Break upgrades</a>
Speaking from personal experience, I think that the n/a (dont know whether '87 had better brakes than 85.5 and 86) has extremely capable brakes. The only situation in which i think turbo brakes may be a plus is on the track. Also, since most n/a cars lack ABS, putting bigger binders would result in massive lockups not only in the wet, but in the dry as well. I believe my wheel/tire setup is the perfect compliment to the n/a brake capabilities and shortcomings. So, if you want better stopping power, play around with some fatter wheel/tire (good tires though!) combos, you'll find that you can be a lot more flexible in your braking.
