Coolant in Oil Mystery - Need Opinions
Last month my car started dumping coolant into the oil. It seems to have started in a short amount of time and was consuming significant amounts of coolant. I immediately stopped driving the car. Milkshake dipstick
* So far I have done a compression test which seems to be on par. Results 160/180/165/160
* No visible signs of white smoke from tailpipe.
* Cooling system pressure test @ 100kpa yielded very small loss of pressure over 15 minutes, results the same while hot and cold. No sign of moisture at all in cylinders after test.
I thought I had this figured out and ordered everything to do the oil cooler reseal. My parts arrived and I went to drain my coolant and found this.
![](http://www.cincymotorsports.org/members/blackeco/porsche/DSC04263.JPG)
No signs of oil AT ALL in the coolant. So could it still be the oil cooler?
I'm starting to think I have a crack in the block somewhere from the water jacket to a low pressure oil passage. I really don't have any idea how this could have happened as to my knowledge the car has no over heated or had any issues.![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
Any ideas besides LS1 swap and doing the oil cooler reseal anyways? According to Clarks Garage the first sign of the oil cooler leak is oil in the coolant and not the other way around. My car was making great oil pressure too.
As always I appreciate any suggestions.
Edit : It was the oil cooler seals.
