944 Turbo boosting and idle problem
I'm having a annoying issue with the 951. When the car goes into boost and if I release the throttle suddenly the car tends to jerk and come off boost not very smoothly. Also, when I'm coasting and off the throttle the car tends to jerk ever so slightly as if someone is going on and off the throttle very lightly. When the car is at idle and warm on some occasions the idle tends to creep up to around 1200 RPM and stay there. Is this likely a problem with a faulty throttle switch or do I also have a turbocharging problem with the wastegate?
Sticky idle control valve? Clean it recently?
Regards,
doug
Waterloo, Ontario Canada, eh
86 951 (http://www.pcaucr.org/index.php/visu...egory&catid=61)
01 E320 (W210) 4matic Wagon (http://www.benzworld.org/forums/w210...body-do-2.html)
00 540i-6 (http:// http://www.trillium-bmwclub.ca/forum...sp?postid=1916)
94 855 turbo Wagon (sold in 09)
85 535i-5 (sold in 07)
76 300D (sold in 92)
83 944 (sold in 86)
I apparently only buy cars designated by numbers
Regards,
doug
83 944 (sold in 86)
http://forums.pelicanparts.com/porsc...procedure.html
http://motoriginal.blogspot.com/2009...cuum-hose.html
http://www.texasblake.com/porsche/tech/icv.html
Regards,
doug
83 944 (sold in 86)
Regards,
doug
83 944 (sold in 86)
