Oil
Whatever you do, don't put the oil all in at once. Put in 5 liters and top off using the dipstick.
Overfilling with oil is almost as bad as running low on it! (Fouls plugs, seals, etc.)
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by '86 944 turbo:
<strong>Thats what i bought 15W50 mobil 1. Very expensive though. I paid $7 a quart. But putting the best oil is worth it. :s: :b:</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Expensive? nah, oil is cheap, use lots.
my brother says that he *has* to use 5w-60 for his e46 m3, and it's US$18.00/litre available only from the dealership. don't think he's looked around, but then again, i have never seen that stuff on any shelf, anywhere. oil is not cheap, but it might be soon thanks to the political aspirations of our president, <shrug>.
20W50 Valvoline Racing-
Good stuff, stay way far away from Quakker State. High sulfur content makes for jello in the crankcase. Seen enough of them to know.
I stick with what Bruce Anderson recommends as he probably sees the inside of more P-Car motors than anyone. Kendall 20-50w which is $1.59 a qt at Autozone. Now for my wifes car, Mobil 1 and it took 8 qts as that is what it was designed to use.
Buy what you like and change it often!!
Amsoil 20-50 for the summer and amsoil 10-40 for the winter...
10-30 sounds way too thin!
Looking at the manual on page 65 it shows 10-30 as good for between ~(-15) degrees F to about 65-70 degrees F.
I'm sure it gets warmer than 65-70 degrees in MA, doesn't it?
<strong>Thats what i bought 15W50 mobil 1. Very expensive though. I paid $7 a quart. But putting the best oil is worth it. :s: :b:</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">I run amsoil in my 93 Z28 w/ 172k on it and picked up almost 2 solid mpg w/ the 20w50 and 7hp on the dyno over valvoline 10w30 dino.
Email me if you need an amsoil dealer or want to try some.
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by deni durrell:
<strong>i was reading on a german board, (no um, running the text thru bf...<a href="http://www.dpb-online.com/board/index.php?board=2;action=display;threadid=2451" target="_blank">DasPorscheBoard</a>) and some guys were talking about putting Castrol RS 10W60 in their 944s... what's up with *that* ??</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">I will second our German colleagues' thoughts as far as the 951 is concerned.
See my post in <a href="http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic;f=18;t=004960" target="_blank">this thread</a> regarding 951 oil.
One of them has a nikasil-treated block on his 951 Cup and runs it with this oil.
