Removing interior door handles???
It's really straight forward. However, I have to ask, why are you trying to remove them? If you are trying to get at somethign else, you'll probably have to remove a lot more stuff.
bull back the handle & you'll see a screw. Unscrew that & remove the trim around the handle. You'll now see 2 (of a possible 4) screws holding the handle itself to the door. Remove them & unhook the "U" in the cable & you're done. 10 minute job.
Only possible catch is you may have to remove the door trim to get to those two screws in the door handle itself. I'm not sure though.
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Scootin159:
<strong>bull back the handle & you'll see a screw. Unscrew that & remove the trim around the handle. You'll now see 2 (of a possible 4) screws holding the handle itself to the door. Remove them & unhook the "U" in the cable & you're done. 10 minute job.
Only possible catch is you may have to remove the door trim to get to those two screws in the door handle itself. I'm not sure though.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">That's the trick. Thank you!! <img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
