968 brake light problem
Hi,
Both brake lights have quit working. The center brake light works when the brake light is pressed, but the ones in the tail lights do not.
Bulbs seem fine. Is there a separate relay or fuse for these?
Something else I can check?
Thanks,
Phil
Thanks,
Phil
Never mind... turns out it was the bulbs after all. Now just struggling with the black plastic piece that attaches to the nut holding the tail light housing on one side of the car.
how do you take of the housing
I ahve looked all over the outside for what you described and I can find an easily removed housing to get to a nut or a bolt. Do you have a picture. I feel like an idiot not being able to take off the brake housing to change the bulb
