Fuel Pressure Damper Leak?
Hi,
When I disconnect the vacuum line from the Fuel Pressure Damper on my '88
944S there is a small amount of fuel in the outlet. Only enough that if you
press onto it with your finger it leaves a small ring of petrol on the skin.
Does any leakage at all mean the damper is shot? If so could this small leak
affect engine running?
Cheers,
Cheers,
