Help in Southern PA area
Does anyone have a working sunroof relay I could borrow for a day? I could pick up and deliver back, a new one is pretty expensive so I'd like to make sure that's what it is before I replace it. Also my dash stopped working (All gauges don't work) and the fuse is okay, any tips?
Did you search Clarks-garage for help.
I had the cluster stop illuminating and it ended up being a fuse although nothing looked wrong with the fuse. I put a new one in and it lit up again and later I found out it was the fact that I forgot to put the license plate lights back in after painting the car and the wires were hitting the metal inside the trunk and shorting and taking out the fuse.
Yes I looked on Clarks-Garage, no help there. It's not that the gauges aren't illuminating, it's that they don't function. They all stay at 0 with the car on. I know the engine doesn't run at 0 RPM!
Not an electronics expert, but personally, I would look for a new cluster. Try to find the cause of the failure first, could happen again.
Then I would find someone in the electronics field to look at the old cluster to see if it could actually be repaired.
But that's just me.
Ken
But that's just me.
Ken
So I'm following the wire (Pin 3 Connector B, GN/BK off of the instrument cluster) in the wiring diagram in the Shop Manual (Vol. 5 Electrical, page 18) and it goes to DME Connection F46. Anyone know where that connector is in the manual?
