Timing Belt and water pump replacement
Just wanting some info on procedures for a timing belt and waterpump job.
I have the Haynes manual but i need more info.
I have an 88 944na
I have an 88 944na
1 Post
<a href="http://www.clarks-garage.com" target="_blank">www.clarks-garage.com</a>
Under garage shop manual there are a bunch of great writeups about various 944 projects.
Good luck, I recommend you replace the balance shaft beltt, and all the tensioners, and rollers at the same time.
I bought the car a year ago. The records indicate a full front engine overhaul at 139k. I will check the tensioners and rollers. I bought a kit from PAP in Murraysville Ga for $250 that consists of rebuilt WP, Timing and Balanceshaft Belts, Thermostat, belt guide and a couple of O rings.
BTW i live in Georgia consequently where do u live im about an hour south of Macon.
