Street-able 944S2 Exhuast Options
Old 08-21-2010, 04:01 AM
sTyleR
sTyleR's Avatar
Default Bump
Paging odurandina...
Old 08-30-2010, 10:59 PM
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
datts it.... and the glory to follow.
you can also run that hollow resonator all the way back in place of the cat... that way you have a small elbow pipe there at the bend going straight into the resonator. that is a very good design.... and only 1 testpipe.
UPDATES ?????
Old 09-04-2010, 08:47 PM
sTyleR
sTyleR's Avatar
My hollow chamber resonator came in today. The max flow muffler came in about a week ago, so I'm situated with the materials. The muffler shop is closed for Labor day weekend. I'm going to run odurandina's setup on my 924S, rather than my 944S2. Updates to soon follow.
Old 09-11-2010, 03:08 PM
sTyleR
sTyleR's Avatar
I was planning on taking the car in to have Midas put everything together today, but they are just too swamped at the moment. So now it's first thing Monday morning....
In the mean time, I'll work on getting a video together to chronicle my exhaust progression.
Old 09-11-2010, 03:28 PM
odurandina
Team Owner
odurandina's Avatar
i hope the muffler shop doesn't overcharge you.... remember to run heavier guage pipes.... and 3 mounting brackets is preferred instead of the normal 2.... why ? cuz now, you're running a lightweight exhaust and it's a four cylinder engine, which will normally beat the hell out of your motor mounts and exhaust pipes.
Old 09-11-2010, 03:32 PM
sTyleR
sTyleR's Avatar
Good tip, will do. Is there a specific point I should have the third bracket placed at?
Oh, and what do you mean by heavier gauge pipes?
Old 09-11-2010, 05:03 PM
odurandina
Team Owner
odurandina's Avatar
14 guage aluminized 0.078~0.083 inch. no thinner.
don't let them talk you into using crap. find another shop.
Old 09-11-2010, 11:53 PM
sTyleR
sTyleR's Avatar
Alright, I just added that to my checklist.
Old 10-23-2010, 08:03 PM
P944S2
P944S2's Avatar
I'm just recently looking into doing a inexpensive way to get more sound of my S2 this sounds like a sound plan...Did either of you guys ever make a video of your exhaust sound with this set up...if not it would be very helpful and appreciated.
Old 10-23-2010, 11:18 PM
odurandina
Team Owner
odurandina's Avatar
i was in kc day before yesterday.
Old 10-24-2010, 07:47 AM
Makis
Makis's Avatar
Will removing the internals of the standard S2 cat make a suitable resonator. Will this setup sound different then replacing the CAT with a straight pipe?
Old 10-24-2010, 10:33 AM
odurandina
Team Owner
odurandina's Avatar
the aftermarket mustang, ford and chevy stuff is pretty good. why shouldn't it be. they've been experimenting for over 50 years,... so, the short answer is NO.... but if you're on a budget, why bother adding greater expense to an already expensive car.
if you go to my exhaust thread https://rennlist.com/forums/924-931-...to-heaven.html you can find the pieces there. my car would top out in the mid 140s before changing the exhaust. i gained about 18 mph after installation.
but the thing you need to remember is, you really need that "big mouth" resonator in there. it's the nature of the four cylinder's exhaust note.... "just too lawnmowery."
someday the car will have the "proper" 8 cylinders.
Old 10-24-2010, 07:21 PM
nzporsche944s2
nzporsche944s2's Avatar
Makis - I had the same thought as you! Opening up the cat and removing the crap and maybe repacking it with internals from another exhaust. That would keep the the stock look
Old 11-13-2010, 04:09 AM
sTyleR
sTyleR's Avatar
Default Exhaust Update
odurandina, as you know I was aiming towards running a setup like yours on my 924S.
I went ahead and purchased the resonator you specified and had it installed in the middle of my straight through setup (towards the headers, as specified). Even though I also purchased the Hooker muffler as well, I decided to leave on my Borla XR-1 to see how it would sound.
Results (keep in mind, I'm comparing the sound to my previous LOUD straight through setup): The idle sounds very much alike from the outside in depth, but is noticeable quieter from the inside. Upon cruising up to speed, a real difference is noticed. The racy loud exhaust note is gone, replaced with a more sportive and suitable tone. It's not quiet, or loud really. I think the sound is just about right for street use. I'm happy cruising at highway speeds and the low RPM groaning is gone. The car doesn't scream under overpasses anymore and the sound is more natural, if anything. I like the fact that I can enjoy my music, while still hearing feedback in between shifts and acceleration. And for what it's worth, I can have a conversation with the person sitting next to me without yelling.
Overall, I'm glad I went with your type of setup. I'll try to get a video up and more updates in your exhaust thread soon enough...
Quick Reply: Street-able 944S2 Exhuast Options
